Boss OD-1 to TS9
Started by Arn C., January 21, 2004, 01:07:52 PM
Arn C.
How difficult is it to change a boss OD-1 to a TS9 tubescreamer?
If it is not to intensive, what needs to be changed?
Arn C.
Joep
Hi Arn,
I think you're mixing up the OD-1 and OD-2. The OD-2 is very similar to the TS-9, some component values are different. The OD-1 is had also a different schematic and only two pots.
Bye,
Joep
Ansil
Quote from: JoepHi Arn,
Bye,
Joep
true true..  also i did this mod, and have a pic of it if you need it.
Arn C.
Thank you for the info.   I have a friend of mine that was wondering if I could do this for him.   That is why I asked.  I guess it can be donw, but way too much for the bother ,  maybe there is a way to make it sound more tube screamer like.   Any ideas?
Arn C.
Ansil
Quote from: Arn C.Thank you for the info.   I have a friend of mine that was wondering if I could do this for him.   That is why I asked.  I guess it can be donw, but way too much for the bother ,  maybe there is a way to make it sound more tube screamer like.   Any ideas?
Arn C.
personally he wants it to sound like a TS right. i would gut it.  go with the lm386 for the amplification.   set it up with a third knob for tone.   and build the freq response around it to be like that of a tube screamer.
it wouldn't take but about a half hour. to build it on perf.  maybe canabilize the switching circit from his board.  that or add truebypass to it.
send me the Od-1 schematic link and i will look and see what else could be done.
Marcos - Munky
Hey Arn, what about build a Tube Reamer for him? You will spend only some parts, and you can use the Boss electronic switch. I think a small piece of perfboard will fill inside of the enclosure without remove anything.
Ansil
Quote from: Marcos - MunkyHey Arn, what about build a Tube Reamer for him? You will spend only some parts, and you can use the Boss electronic switch. I think a small piece of perfboard will fill inside of the enclosure without remove anything.
good idea, there munky.   i was goin to say that earlier, but you beat it too me.  :)  also check the tube reamer thread tehre are some mods i posted about it, for a littel icreased response
Arn C.
Thanks for the tip guys!!!
Arn C.
