Hard Wired Mid Scoop Eq Type thing
Started by petemoore59, August 27, 2003, 11:32:51 PM
petemoore59
After readin on the discussion about getting that metal sound...I got to thinking one might use a "MidScooper" type Equeing ckt that scoops Mids [doh] at a preset level, [seems this would be simpler and less knobs for sure than an EQ build] of better yet has a small amount of control over the 'where' [frequencies affected] or 'how much' what amount of cut a Freq band would have.
 I'm not the breadboarder [I need a surfboard to surf thing] type guy just yet, however it just seems I had the urge to post this...it's an interesting area for exploration and application...I'm sure there's must be some existing ckts around that do this..
Ansil
did this, its on my site, i fyou wish to check it out, uses a switch to go between happy and sad eqing.
www.geocities.com/austenfantanio/snips
sfr
Does anyone know at what point the appropriate "mid" range would even be defined?  I mean, I assume it's a matter of taste, but where would you start shooting for?
Also, (and I'd post this back on the other message but I don't seem to remember which one it was [nothing is jumping out at me at least]) but if somebody does go the heavy distortion plus scooped-mids route, I'd really heavily suggest adding a compressor, at least if you plan on playing any of those "chuggy" palm mutes that seem stereotypical in the style the original post was refering to  - in my experience, scooping the mids and rolling on some more bass for that sort of tone, something about it makes the palm mutes louder than regular strumming a lot of times, (it's odd) often times to the point where it sounds wierd or distracting and isn't really compensatable by playing with a different touch.  Of course that might just be because I almost always use the bridge pickup.  (If I could ever get a working tone out of the neck pickup . . . )
AllyP
hmmm Interesting concept.... :wink:  What about changing the eq on the fuzz for 2 pots:  Bandwidth and Boost/Cut......Seems pretty simple Looking @ the scheme on Ansils site....
Ansil
1k to 1.5k is the freq to cut to tighten up your sound.
AllyP
Oh BTW it was my "The never ending search....continues" post! :D
Ive been working on an updated tone stack design thingy for the Obsidian...I call it the Obqueliser!!!
I was thinking of adding parametric eq or a tweeked amp eq(Im looking @ the vox one in Duncans TSC as it seems to have excellent mid cut :))
I'll let you know how it goes!
WGTP
Doug Hammond's Sweet 16 has a passive mid-notch after a dual mu-amp distortion.  It works pretty good.  I added a switch to by pass it for the straight tone.   8)
Stomping Out Sparks & Flames
Ansil
ALSO FOR A NICE trick before distortion use a 1:1 isolation transformer its freq response is 300hz to 5khz.  interesting pre shaper with no need for an input cap
