CA3094
Started by shawsofhell, February 05, 2004, 11:45:41 PM
shawsofhell
Hi I found a supplier near me that sells the CA3094AE chip is this the same a the one that appears in the small stone. ie will it work in a small stone
dr
....yes,it will work....I used both ca3094as as well as ae versions in the small stone clone I built...they both sound similar....I'm fond of the ae myself-its the one in the "tin can"......
Muldoer
If you are referring to the layout on Tonepad, no, it wont work.
dr
....the one I was referring to was the small stone layout in General Guitar Gadgets-it uses the CA3094;its the one I built.......
anyuser00
Would you mind naming the distributor/cost :?:
