miss piggy - transistor problems
Started by vdm, February 07, 2004, 09:07:21 PM
vdm
hey guys,
after reading along with the piggybacking trannies thread i was inspired to try and build a miss piggy. so yesterday i went out got all the comps and got home and soldered it all onto some perf.
i turn it on and all i get is very quiet hum.. no sound. then i remebered the trim pots and set them both to about mid way hoping that i had just made a stupid mistake and they werent's getting voltage, but alas no sound.
i got out my audio probe and started poking - the beginning of the circuit was giving signal - but as soon as i got to the first transistor - the sound stopped. i changed the battery to make sure that wasnt the problem, but still nothing. i twiddled with the trim pot some more but no cigar.
i don't have a multimeter and was wondering is there an easy way to see if a transistor (or any component) is getting power?
other than that - does anyone have any suggestions as to what the next plan of attack is?
thanks guys,
trent
javacody
If you have any LED's, you can check for voltage by seeing if it lights up.
RobB
You really, really, really should buy a multimeter.
The circuit you want to build looks simple but the concept of piggy backing two si transistors is still very new and experimental.
I couldn't imagine doing electronics without one.  That would be like a carpenter without a tape measure.
Save up for one.  In terms of functionality (bang for your buck), they're cheaper than they've ever been.  Get one with a transistor gain tester.  You'll find other uses for it such as automotive electronics,  checking power points etc... (once you learn how to use it).
Have a look at jaycar and dse.
javacody
I got one for $5 off of ebay. It doesn't test capacitance but it does test resistance, voltage, and hfe among other things. It also tests for continuity.
mattv
First couple of steps, check your transistor pinouts and make sure they're getting power.
smoguzbenjamin
I got my relatively accurate DMM for about $10. It measures everythng except capacitance, and up to 600v AC and something like 250V DC. They're relatively cheap, but the price jump from cheap-sortof-accurate-good-enough type DMM's to accurate high-quality DMM's is large.
brett
Hi.  I might be partly responsible for this - are the transistors in the right way around?
The Miss Piggy layout suggested using PN100 transistors but I showed the transistors facing the wrong way for PN100s (at least the ones that I got from DSE).  If your transistors are collector-base-emitter when facing you (ie flat side), then the flat side should face *left* on the circuit board (ie the input end).
It's definately worth perserevering - the Miss Piggy is a totally awesome fuzz.  The more I play it and the more I compare it with other circuits the more I realise how very good it is.
Also, get along to Dick Smith - they had multimeters for $10 recently.  Alternatively, the one I use is from Jaycar and only costs $16.  When I started to get into experimenting with circuits I bought an oscilloscope off ebay for $60.  At the time I thought it was a bit over the top, but I use it heaps (especially when stuff doesn't work!).
Brett Robinson
