McMeat - Clone of a famous envelope filter
Started by Joep, February 14, 2004, 05:05:24 PM
Joep
Hi All,
Here you can find the McMeat, a clone of the Lovetone Meatball.
I'm pretty sure we debugged the layout, so it's released now.
Many thanks to Moosapotamus, for his great pre-work on this. Without him this project would not have been possible!
Good luck building,
Joep
Bill_F
Marcos - Munky
Dan N
Joep,
I can't get the pdf to open. Was Charlie's schematic (meatball_v2.png) correct?
Thanks,
Dan
Joep
Hi Dan,
Strange, I guess you need Acrobat 5 or higher to open it.
Actually the only thing wrong in Moosapotames' schem way the decay pot was wired. A lot of people (incl myself) were tricked by the way the envelope detector looks. That looks rather funny electronic wise.
Send me a PM and maybe I can send you the stuff in an other format or something.
Bye,
Joep
Gripp
So cool!!! Not a long wait after all  :wink:
Thanks a lot guys!!!
Best!/
Pelle Garpebring
smoguzbenjamin
Wow. How the hell am I gonna fit all those knobs on a BB sized box? :shock: Otherwise I won't be able to fit it on my pedalboard! :cry:
ExpAnonColin
Roxxor!  When work-alike is said, does it mean clone or something that works the same?
-Colin
ExpAnonColin
Quote from: smoguzbenjaminWow. How the hell am I gonna fit all those knobs on a BB sized box? :shock: Otherwise I won't be able to fit it on my pedalboard! :cry:
If you used a 1590S, which is basically a deeper and tiny bit smaller BB, you could probably fit all of the knobs, but you'd have to use sub sub mini knobs, pots, and probably split the circuit board and use a jack and no battery.  It could be done!
-Colin
smoguzbenjamin
Could be done but on my almost non-existent budget I can barely afford the mini mini stuff. In holland they charge you more the smaller it gets. :(
Dan N
Joep
Hi Colin,
There a few minor differences with the original.
- No expresion pedal support
- True bypass
Bye,
Joep
Gringo
Quote from: JoepHi Dan,
Exactly. I have acrobat 4 and it didn't open, but worked just fine with acrobat 6.
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
moosapotamus
Nice work, Joep.  :wink:
~ Charlie
moosapotamus.net
psst
I built mine with Joep's PCB, it works perfect.
Actually, I built mine with Expresion Pedals support too.
The only thing you have to do is wire the pedal1 and pedal2 jacks like this:
(Sorry it's in spanish, it's for an article I did for pisotones.com, that will be available in 2 or 3 days)
This way when pedal1 is not connected, tip of Decay is connected to ground, but when it's connected, it's disconnected to ground and connected to pedal1 (which connects to ground through the pot, anyway).
(self explanation)
psst
Thanks to the GREAT work done by Moosapotamus and Joep, I built one too, working perfectly.
I wrote an article for Pisotones (in spanish, sorry) with photos and mp3:
http://www.pisotones.com/Meatball/psst/meatball-psst.html
Manolo Dudes
Quote from: psstI wrote an article for Pisotones (in spanish, sorry) with photos and mp3:
Amazing!  :wink:
a.k.a. "Calambres" in www.pisotones.com
MarkB
Wow
Wowwowwow... both of those builds are amazing!
Psst - which PCB layout did you use? Moose's?  and is that a Hammond 'D' box?
Joep - I love the silver knobs..
man - those builds are amazing...  hmm, do I need an envelope filter?
troubledtom
very nice job gent's!!!!!! wish i could read spanish  :oops:
       truly great,
           - tom
