MN3005 for a Deluxe memory man
Started by Prive, February 26, 2004, 01:00:11 AM
Prive
Hi, i found a pair of MN3005 in a store here in Argentina, U$D 10 each.
I think, i'm building a Deluxe memory man now!!!!!!
But, i see some things that make me think a little more about the proyect.
The MN3005 have the size of a 16pins IC but have just 4 pins in one side and 4 in the other,  like if 4 pins in the middle of each side was missing, it might be like this??? or this are other type of IC????
I'm thinking in the The Edge sound of the early records, if you can't mix the delay with the chorus, there must be some subtle differences between DMM and other analog delays or PT-80, maybe the delay time, 500ms or so.
Anybody build this pedal???
Please any suggestions are welcome.
Saludos, Marcelo.
Fuzz boxes don't need on/off switch!!!!!!!!
ExpAnonColin
Nope, it should certainly have only the 4 pins.  What a great find!  Good luck.
-Colin
uncle boko
Hi Marcelos - where in Argentina - in BA?
better to be in bad taste than to taste bad
uncle boko
Hi Marcelo - where in Argentina - in BA? My wife went to Northlands school in BA, do you know it?
Gringo
Che marcelo, recibiste mi ultimo mail?
Buenisimo lo de los chips, a ver para cuando unos clips ;)
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
Prive
Gringo, no recibi nada, podras reenviarmelo???
Si buenisimo pero no estoy seguro de que sean los que deben ser ya que le faltan patas.
Uncle boko, yes i'm in Buenos Aires but i don't know that college.
Colin (annonymous) sorry i don't understand you very well, is ok this MN3005??? it has just 8 pins and the schem have connections to pin 5 and so, how can it be????
Marcos - Munky
Go and buy them, they have only 8 pins. In Mark Hammer's site you will find the datasheet for it.
