scrambler transistors
Started by leonhendrix, February 26, 2004, 06:40:29 AM
leonhendrix
hi
I'm making the ampeg scrambler and because I live in the uk I cant get hold of the 2n5306 darlington transistors. So what other darlingtons could I use
thanx
leon
Bassybert
Didn't Jimi have a brother called Leon?
Jim
leonhendrix
Didn't Mr & Mrs Morrison have a son called Jim
The MPSA14 is shown as an acceptable substitute at Tonepad.  I made one with MPSA13 darlington's and it worked fine.  Every bit as rude-sounding as you'd like.
niftydog
2N5306 equivalents according to my transistor books;
The MPSA14 is practically the same transistor... it has even better specs.  Probably an improvement on the original.  MPSA13 is also very similar.
2N5305 is also much the same
BC517 and BC617...
niftydog
Shrimp down the pants!!!
computerjones
just curious if someone has A/B'd these with darlingtons vs. BJT's.  i built this a long time ago and just used generic BJT's but im wondering if anyone has tested to see what the difference is???
thanks for your time.
