BOSS DD-2 making bad noises. Help needed
Started by smoguzbenjamin, February 26, 2004, 10:33:38 AM
smoguzbenjamin
Hey guys
I have a boss DD-2 and when I stomp it on it goes Bonk Bonk bonk bonk bonk ... It's pretty annoying and sometimes it just goes bonk once and stops working, then I tap it with my foot and it goes bonk an works again. I got it for free because it did this and I think it's time something was done to stop it doing that... Any ideas what could be wrong with it? :?
Cheers
Ben
Fret Wire
Dead battery, bad switch, loose jacks? Is the plastic insulator sheet still between the pcb and bottom plate? Sounds like a short.
Fret Wire
(Keyser Soze)
Chris R
Quote from: smoguzbenjaminI tap it with my foot and it goes bonk an works again.
This makes me think that something is shorting out.  Are the jacks good ?
C
smoguzbenjamin
Jacks are fine, wiring's fine. I use a wallwart and my 5 other pedals are pretty happy ao that's not it. There's still a plastic plate between the box and PCB. I have taken a look and I've noticed that
A) the rubber ring for the battery hatch is gone and
B) That when I press the footswitch and then push it down a little bit as if there were a rubber ring, the delay comes on no problem sometimes but not always.. grrr :x
Maybe it is the switch... Lemme see
Fret Wire
If the rubber grommet is gone, that would allow the switch to be pressed down a little bit further. I don't know if that would be enough to damage the switch? My CE-2 acts like the switch is bad the minute the battery gets a little weak. Drives me nuts! Did you power it with the wallwart all by itself? Smallbear has the replacement switches pretty cheap.
Fret Wire
(Keyser Soze)
smoguzbenjamin
Even with a fresh battery at 9.3v it does the wierd noise. I screwed it up a bit tighter, now if I'm gentle and lucky it doesn't make a lot of sound when switching on, but I can't stomp it hard...
