Adding a Depth Control to a Phase 45
Started by Mobisimo, March 15, 2004, 09:58:36 PM
Mobisimo
Hey all,
Is it possible to add a depth control to a phase 45 clone.  Heres a link to the schematic and layout at tonepad.  Somebody mentions it in the build reports, but doesn't go into much depth (excuse the awful pun).
Thanks in advance.
http://www.tonepad.com/project.asp?id=13
Also, if anyone has experience with this project, any advice or findings would be much appreciated.
brett
Hi.  I built one of these a while ago.  It offers a nice depth of sweep in standard form.  I doubt that you'd find it too deep.  Alternatively, if you want it permanently mild you could choose FETs that aren't well matched.
cheers
Brett Robinson
brett
Looking at the schematic, the dry signal and phased signal are mixed just before the output cap.  The mixing involves 2 parallel 10k resistors.  If you replaced these 2 resistors with a pot, so that dry and phased were connected to lugs 1 and 3, and the output taken from lug 2, you'd have a control where maximum depth would be mid-turn on the pot and minimum depth would be at both max and min turn.  I think a 25k(B) pot should work.
Ask again if that's as clear as mud.
cheers
Brett Robinson
Mobisimo
Thanks for the reply man.  I like the idea with mismatching the jfets, thats some creative thinking.
As for the pot, I was kinda thinking the same thing without the resistors.
If you say the depth is nice though, thats good enough for me.
Thanks again.
Gringo
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
Mobisimo
Thats pretty sweet stuff.  Thanks a lot man.  I'll let you all know how it works out.  Might be a little while...
