true bypass with "blinking" LED possible?
Started by MarkDonMel, March 17, 2004, 12:19:07 AM
MarkDonMel
Hey all,
I was going to order some LED to use as on indicators on a couple pedals I want to build.  Is there a way to have them blink when the pedal is on instead of just being all the way on constantly?  And, maybe be able to have a variable blinking rate via a pot or something? Say from a slow blink to a faster strobe-like blinking?
Thanks, Matt.
Ipso Facto
MarkB
Courtesy of Joe D..
Though, I think you can get blinking LEDs anyway..
MarkDonMel
Thanks MarkB.
As a beginner I am going to have to have a second look at that circuit but it looks doable for me.
Thanks again, Matt.
Ipso Facto
ExpAnonColin
You also could use many waveforms, IE a 555's astable multivibrator, to power the LED.  YOu just replace the 9v on the switch with the waveform, given that the voltage and current are all right.
-Colin
casey
cant you buy l.e.d.'s that blink by themselves?  i think i have
even seen this at radio shack....
Casey Campbell
Gilles C
Hum... what is the link for the changing color LED?
I just had a rush to build one...
casey
Casey Campbell
gez
You can do a 'flashing millennium' using CMOS inverters.  Layout is everything with those type of oscillators (simple square wave type) though as it's easy to accidentally introduce ticking.
Gilles C
Paul Marossy
I do believe that RS sells flashing LEDs, no external circuitry required.
