DIY Attenuator HELP PLEASE
Started by Mike, March 17, 2004, 03:28:03 PM
Mike
OK I've checked the schematics page and the links have errors.
Does anyone know where I can get schematics and instructions for building my own Attenuator.
At this point I'll take what I can get but ideally something like the following
These would be for 100w amps, ohm adjustable if possible
Webber Mass Attenuator
Dr. Z / Tranwrieck Airbrake
THD Hotplate
Powersoak
Any helpl much appreciated.  I'll kick myself in the head if I have to pay $300 for one of these.
:lol: THanks
Mike
my hair is on fire
Craig V
Mike
Thanks Craig
I guess I'm too muich of a Newbie to translate that into perf-board layout.
I was hoping to find detailed  instructions on GEO or general guitarvgadgets or something.  NObdy seems to have these.
My quest conitnues.
thanks for the schem
Thanks again
Mike
my hair is on fire
That one's from the Weber page, uses a large 'draw motor' like a dummy speaker coil.
 I thought of just trimming and damping the heck out of a speaker coil, and connecting that with speakers to load the amp and draw alot of power to the dummy speaker [which would be lower Ohms so it would get the lions share of the output power].
 I had [have?] an attenuator built for me from very large 'brick' resistors...the ones that converted much output power to heat were seriesed [a lot of surface area for heat dissipation] and got quite hot]...these IMO 'mush' the sound a bit.
 I like the Weber idea of a dummy draw coil...well
 I use a 50w amp for gigs lately
Ansil
aron
QuoteI guess I'm too muich of a Newbie to translate that into perf-board layout.
Mike,
That's a PERFECT schematic to start with.
Ignore the tone stack parts and you only have a speaker, resistor, pot and jacks.
You try and sketch it out and we will help you correct any mistakes you make.
You don't need perfboard for this one. Point-to-point wiring! :-)
Alpha579
Where do u get those mass motors?
Alex Fiddes
aron
From WeberVST. I have 2 of them, they work.
clutterbuck
Hello all, back after a long long break.
I am in the same situation as mike. The weber schem seems very simple. The circuit is describes as being for a 25watt load. If I wanted to scale this up to a 100w load what extra is entailed. Do the values for the resistors remain the same?
I like the idea of having variable attenuation. The L pad idea won't offer me that without going into building a design based on several pads switched via a rotary.
V!N
Quote from: Ansila light bulb works great
.. excuse me ? :shock:
javacody
What is a mass motor? How do you control the volume from the attenuator? How loud will this be?
clutterbuck
Basically it is a coneless speaker. The schem shown uses var resistor to control the volume much as you would in a pedal volume control. It's just the values that concern me. :(
http://www.webervst.com/mass.html
Ansil
Quote from: V!N
i dont' have the exact schematic on me right at this moment i am out at library  but however  basically u put a light bulb standard hosue isue  or a neon is my favorite
and it will eat up extra power from power amps, it has been done in large pa cabs for years..  u can see them light up thru the port holes when they are pushed too hard
the guy i used to work for showed me that.
Nasse
Ansil wrote
Quoteit has been done in large pa cabs for years.. u can see them light up thru the port holes when they are pushed too hard
:shock: Yeah I remeber I have a circuit lying somewhere (think it was thorough article in some old Elektor Electronics) using lightbulbs to protect tweeters in hifi and PA. Maybe I´ll find it some day, but dont know what year and month :oops: But it was useful simple and cheap and goodsounding trick imho. Maybe some day I´ll take a copy from December issues mag index pages and archive these papers well... It maybe has something to do with my childhood, too much wooden toys and such :wink:
But just remembered this link http://www.kolumbus.fi/mikko.esala/diskanttisuo.pdf
looks like power mosfet version of tweeter protection, maybe useful if it works, dunno. It says there must be a series resistor in series with tweeter in crossover circuit to make it work, and some good heatsink is needed
aron
Quote from: clutterbuckHello all, back after a long long break.
I believe a 100WATT MASS motor and possibly adjustment of the resistors. The resistors as shown are pretty darn soft as far as output volume goes.
Doug H
Quote from: aron
You will need a higher power rating on the resistors.
Doug
V!N
Quote from: Ansili dont' have the exact schematic on me right at this moment i am out at library  but however  basically u put a light bulb standard hosue isue  or a neon is my favorite
Oh my, how do they come up with stuff like that. :)
Sounds like a great and inexpensive way, but how safe will that be for the transformers of a cranked tube amp ?
I'm affraid a bulb is more fragile than Teds MASS motor.
Peter Snowberg
Lightbulbs can make very effective over-current protection in some cases, but as a speaker emulator????  :!: NO... forget that one quickly.
The impedance will start off too small (100W lamps have a very low resistance when cold) and then quickly get too large, never fully recovering to the too small area... but everything is 100% RMS output dependant. They work great for regulation in Wein bridge oscillators because they sit in the feedback loop (taking advantage of their negative resistance), or for a sort of over-current breaker in testing amps and appliances, but as a speaker load.... no chance. BTW: Neons will not work in the slightest for this application. Those are a totally different animal.
I would hate to see somebody blow their amp trying this.  :(
Take care,
-Peter
Eschew paradigm obfuscation
MarkB
I used to run sound at a club.. the place sounded GREAT... and when we pushed it too hard, it was a light show.. the 'community' speakers used in the PA had the lightbulb overload circuit in them.. it was kinda funny to see it.
Ansil
of course i am not suggesting them as a speaker emulator i am suggesting them to suck up power,  and well as i always state your expriences just like mileage in a car may vary, but personally when i learned this trick i found out that one of my favorite local guitarsist is using this trick built my a friend of ours to take the output of his 100watt marshall and to drop it off enough to use that into a effects rack.
as he as a powered mixer with built in fx and stuff.
anyway so far he has used this thing for 8+ years on a tube marshall 100 watt head.. and well it works.  as far as a direct lpug in for the weber mass schematic no..  but it is in the same principle and well you can try it if you wish.  i have had good luck with it myself and had no problems as i have borrowed the thing when i used to use a 5150 head, that just didnt' sound good unless it was past 6.
