FET Distortion method?
Started by freebird1127, March 23, 2004, 09:29:44 PM
freebird1127
Ok so I'm a little confused...
When you use a FET to create distortion (or a BJT, I suppose), do you amplify the signal with the FET past the limitations of the FET (past the supply rails, thereby clipping it), then attenuate the output to line level?  And what is line level anyways?  I mean, what do most pedals output in terms of voltage?
Thanks all.   :)
Evan Haklar
What's the difference between incompetence and indifference?  I don't know and I don't care!
Alpha579
Im pretty sure there isnt really an average output of pedals, but by putting a volume control on the end of the FET will control the output of the effect...
Alex Fiddes
freebird1127
Yeah... While I'm sure you're right about that, part of my point/question is that there's a BIG difference between dialing from 0-1Vpp and dialing from 0 to 100Vpp (obviously I'm exaggerating  :P), regardless of pot size.  So there must be an 'average', I'm thinking, that you have selectivity from... yeah?
Evan Haklar
Alpha579
Ok, yeh see your point...Afraid im not sure... :?
Alex Fiddes
Transmogrifox
Try to keep the maximum around 3 Vpp.  A good example of a pedal that gets too hot is the simple version of the SmashDrive.  I put a volume pot on that one and NEVER got it above half way (which is pretty hot), and that's just over 3 Vpp at half way.
trans·mog·ri·fy
