How can I make a reverse log pot?
Started by toneless, April 01, 2004, 06:42:03 PM
toneless
Hi.I'm trying to make a reverse log potentiometer.Does anybody know how can I do this? I've read the "secret life of pots" article at geofex.com
but my english are not very good -my math aren't either- and there are
no examples in the article :(
Let's take a 100k linear pot as an example.What taper resistor shall I
use and where I must connect it?
Thanks in advance
brett
Hi.
If you are using the pot as a variable resistor (e.g. the "drive" pot in the RM Axis fuzz) then you can use lugs 2 and 3 of a log pot.
If it's being used as a voltage divider (all 3 lugs are used), then you can connect a resistor fom lug 2 to lug 3.  For a log taper, the resistor should be about 1/3 of the pot value (eg 100k pot, 33k resistor).  That makes a 33k reverse log pot.
To make a 100k reverse log pot, start with a 250k pot and use a 100k resistor.
(by the way, a linear pot doesn't usually sound too odd in place of a reverse log pot)
hope this helps
Brett Robinson
brett
Oops.  I think I got the lugs wrong.  The geofex article will explain which lugs. sorry  :oops:
Brett Robinson
toneless
Ok!Thanks.
I think I've got it now.
