Vulcan Tone values
Started by Michael Allen, April 02, 2004, 05:28:54 PM
Michael Allen
I put a modified tone control from Mark Hammer's Chaos into my Vulcan but it's not working like I want.
As is, the most trebly it goes is less than what it already was without the tone control. From there it just goes more bassy and flubby. Any ideas as to what values I should start changing or modifications i should make?
Here's what I put in.....
Thanks,
Michael
aron
hmmm, can't see the picture.
aron
QuoteAs is, the most trebly it goes is less than what it already was without the tone control. From there it just goes more bassy and flubby. Any ideas as to what values I should start changing or modifications i should make?
Hmmm. I know what you are saying but it's a passive tone control and the 500pf will simply pass what is already there out.
For the similar number of parts, you might as well try a Big Muff tone control. It's going to be very easy to try it and you can use the Duncan Tone stack simulator to really dial in the response you want.
Michael Allen
sounds good...i'll try it
