Power Supply question...
Started by crawler486, April 19, 2004, 04:03:38 AM
crawler486
Hello guys.
I bought a 24 volt transformer for
my "Ultra Clean 9v Power Supply"  project.
On the other side of the transformer opposite
the terminals you connect to the mains,
there are 3 terminals labeled 24v,0,24.
I tapped only the left 24v and zero and seems to work fine.
But do I have to connect to both 24v terminals?
Does that makes sense? Not very fluent in english.
spongebob
Quote from: crawler486
That's ok, you could use the other terminal to create a negative DC voltage, for a bipolar power supply for example.
Can't you get a transformer with a lower secondary voltage? 24V is a lot more than you need for a stable 9V supply (it will be around 30V DC after rectification), so the voltage regulator will produce a lot of heat, make sure you use a heatsink!
crawler486
24 volts is the one listed in the bill of materials.
I'm planning to use it to supply about five guitar effects
all (including the power supply) in one enclosure.
Gnome
I think if you use the two 24-plugs, and wire the 0-one to the ground, it will be more silent. If I'm right, it is a center tappet tranny, so it will make the ultra low noise supply even more ultra silent, if I'm right.
