Building a Tim Escobedo's TMK
Started by webero, April 21, 2004, 04:46:31 PM
webero
Hi
Im gonna build a TMK (visit http://www.geocities.com/tpe123/folkurban/fuzz/snippets.html)
Im not sure about the diods marked with "Si". What diods are they?
Has anybody a PCB layout of the TMK?
Has anybody a web about this project?
THANK U
Webero
La madre que pario a la electronica !!!
smoguzbenjamin
Si diodes are diodes made of Silicum, like the 1n4148 or 1n914 :) You also have Ge diodes which are made of Germanium ;)
Marcos - Munky
I don't know anything about a online layout of this effect, but I can try to draw one. Send me a e-mail.
Dan N
That one might be a fun exercise in how many parts you can leave off a pcb and just have them soldered pot to pot...
Marcos - Munky
Sorry, I don't know what I was thinking when I posted a reply here. I ALREADY DID a layout for it some weeks ago. I sent a P.M. to Tim about to post the layout for the TMK and some other effects, but he didn't sent me a reply. I think he didn't received my P.M.. Send me a e-mail and I will send the layout to you.
Tim Escobedo
Hey sorry for not replying. I never realized the messages were there. I forgot of that capability.
All the info is on the schem. While it's not a sophisticated circuit, it has lots of "flying" connections. Easy to screw things up.
Marcos - Munky
http://www.geocities.com/munkydiy/tmk1.3.gif
I uploaded it, but didn't added it to the schematics list yet, because I will try to rebuild my site. It's untested, but I think it's right. If you use it, let me know if it works.
webero
Woah! its incredible
This forum is burning!
Thank you for all of the replies!
Ive got some questions about TMK (sorry Tim, but I think TMK is not so easy as you say)
What kind of diods has been used? sylicon-made I  know, but what value? or what capacity or something like that?
OpAmp is one or two TL062 ?
Ive got different pots (not 250k but 220k, not 500k but 470k, not 50 but 47). It'll affect the results?
By the way, pots are log or lineal?
I need a layout or a scheme where different components are shown
Thank u again !
One thing more: http://www.geocities.com/munkydiy/tmk1.3.gif is wrong !!!!
it doesnt work !
Peter Snowberg
Quote from: weberoOne thing more: http://www.geocities.com/munkydiy/tmk1.3.gif is wrong !!!!
it doesnt work !
When you see a picture posted from a geocities address like this, you need to copy the address and paste it into a new browser window or else it will not work. They do that to stop you from viewing things on their servers without watching their advertising too.
Take care,
-Peter
Eschew paradigm obfuscation
Tim Escobedo
Diodes marked "Si" are silicon. You can use any thpe of common silicon, such as 1N4148, 1N914, 1N4001, etc. Not Germanium or Schottky diodes such as 1N34, 1N60, 1N5817, etc.
I specified a TL062 dual op amp. I tried several but I liked the way these work best. The circuit uses a single TL062.  It may also work OK with two TL061s.
All the pots I used are linear taper. Substitutions are OK, such as 470k instead of 500k. Close enough to work.
I don't have a layout. It's wired on perfboard. I've only glanced at Marcos' layout. If I may be so bold, I suggest you not try this circuit until you've successfully completed several less complicated circuits and played around with them a bit. There are lots of pots to wire up and the TMK offers a great deal of ability to oscillate uncontrollably.
Dan N
Marcos, you need to double check your layout. Looks like one connection of P3 need to be moved to pin 2 of the opamp. Have not checked further.
Marcos - Munky
Thanks, Dan. I will take a look.
EDIT: Thanks a lot, the layout was wrong. Both side lugs of the P3 was connected in my layout. Now I corrected it, it's the same link.
bobbletrox
I love Tim's circuits.  They're small, yet make really unique sounds and are a great chance to use interesting ICs.
:o
Marcos - Munky
Quote from: bobbletroxI love Tim's circuits.  They're small, yet make really unique sounds and are a great chance to use interesting ICs.
:o
I agree!!!!!! :twisted:  :twisted:  :twisted:
webero
Excuse me but... What is exactly a "jumper"?
Ok, i know, im not an electronic engineer...
Marcos-Munky: are U sure your layout is alright?
Greetings 4 everyone!
webero
Marcos - Munky
I think the layout is correct. I didn't tested it. You can check it yourself to see if you find any errors. A jumper is only a wire to "jump" a track in the PCB. You can use a piece of wire or a resistor leg. And put it in the components side of the board.
webero
Hi Munky
Thank u so much!
Ive got some occupations this week but, in 10 days, im gonna try to build that piece of art !
Thank u again
i see you in 10 days
Marcos - Munky
OK. I'm very curious to see a review of it. The soundclip is very cool.
webero
Hi to everyone (specially to Marcos - Munky)
Im just building a TMK using the Marco's PCB.
The effect doesn't work (obvously!) and I don't exactly why but I think it is something related with the "ground".
Does anybody know how can I join the cables to the ground?
Is the ground the same as "-9 V"?
My guitar doesn't sound. The only thing i can hear is a hum
Another question: how can i connect the input and output jacks?
Javi
Samuel
a jumper is just a piece of wire - place it in circuit just as you would a resistor. I personally, when going through and clipping off the extra lead length from components after soldering will save the clippings to use as jumpers. The idea is to allow a trace in the circuit to "jump" over one or several other traces without making electrical contact.
