Building a Tim Escobedo's TMK
Started by webero, April 21, 2004, 04:46:31 PM
webero
Thank u so much but my question is:
what is "ground"? where can i connect to "ground"?
I think this is my problem
And i don't know how i can connect the jacks
Please, look at the pcb layout and tell me why there is just one point to be used for "guitar in" and one point for "guitar out"
La madre que pario a la electronica !!!
Marcos - Munky
Connect the guitar to the input and the amp to the output if you won't try it with the switch. Connect ground to the jacks' sleeves (the point that are in contact with the iron "hole" of the jack) and connect -9V to the ring of one jack. Then the power in the circuit will be on when you have a plug in the jack. See this pic for more info about the jack:
webero
Hi
This is what i've done
Please, tell me where is the error
By the way, what's up with the capacitor near OUT point? why there is no connection?
Javi
Marcos - Munky
www.geocities.com/munkydiy/pic.gif
Part of the offboar wiring are wrong. Hope you understand my quick draw. Sorry, that pad goes to P6.
webero
Hi Munky
I cannot view the pic
Im fed up with geocities. Its a f*** shit!
Could you send me the gif to webero@ya.com ?
Marcos - Munky
webero
THANK U SO MUCH!
Im gonna try it!
I see you tomorrow (its too late for me now!)
Cross your fingers!
Thanks again!
Bye
Marcos - Munky
webero
I've applied the mods to the circuit
I think it works because it produces some kinds of noises but they are not exactly as the mp3 you can hear in the web.
Probably it is because the pot 2 i've got is log (non linear) and it is posible there's some bugs after all.
I'm gonna go on and see where's the problem
I see you later
Marcos - Munky
Well, this is a start. There are some noises in the sample that can be got turning the pots when you play some note.
Tim Escobedo
With all those pots, it's quite possible to make it oscillate several ways. with some settings, you can "play" the circuit all by itself. At other settings, the guitar's volume and tone controls control the oscillating points.
One thing to notice, even with all the knobs, there is no real "gain" control. P3 is the closest thing, although I view it as more of a "tone" control. And it's very interactive with P1 and P2.
Hope it makes good noises for you.
gogiche
I have build the effect and it works grate...also I did substitutions with most common pots such as 500K-470K but I have a small problem with that pot.When its in the last 1/4 it screams just like you search radio frequencies can some one tell me what is the problem?
gogiche
I have also changed the 500K with 1M the problem (screaming sound in the last 1/4 of the circle and max) how can I repair this...?? :icon_frown:
Taylor
It sounds like it's working the way it's supposed to. That shreaking is part of what it's designed to do, I think. Listen to the sound clip here and see if this is what yours sounds like:
http://www.jiggawoo.eclipse.co.uk/guitarhq/Circuitsnippets/tmk.mp3
gogiche
Yes it's working grate except the 500K pot...so everything is nice in the 3/4 of the range of the pot...after or before(it depends how you'll connect it min of max on the left or right) there is a sound of screaming like microphonia or like when you search for radio-station piiiiiiiiiiiiiiiiiip  :icon_redface:  I have build it from the gaussmarkovwww.gaussmarkov.net webpage
