bazz fuss
Started by Mirlyn0, April 28, 2004, 02:49:25 PM
Mirlyn0
ok, i got it all wired up and i used a socket for the transistor, everything is perfect but when i put in the transistor i get no sound unless i turn the amp up to 10, i tried reversing the transistor and trying other kinds (2n5088, 2n3904) what could be wrong?
also when i unplug the transistor i get normal volume sound
if i knew where i was going, i would already be there
Chris R
do you have the diode in the right way ?
Chris
Mirlyn0
im not sure the black cathode thing is pointing away from the transistor, is that right?
brett
Black mark to the base (middle leg).
Quotealso when i unplug the transistor i get normal volume sound
That's ok.  I *think* the diode will conduct when the tranny is removed.  The signal is just modulating that conduction.
good luck
Brett Robinson
