easy question- but i forgot
Started by jimbob, May 04, 2004, 12:57:11 AM
jimbob
Which side of a led 5mm is negative..the long end or short end? I cant remember..i think the short but not sure..
thanks
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
Sic
yup, the short end... and the side with the flat part...
you could test by putting a resistor on what side you think is negative and connect it to a current higher than 1.5 volts.
i believe red needs 1.5 volts or more...
