what is an LDR
Started by { antonio }, May 22, 2004, 10:56:39 PM
{ antonio }
i wanted to know if you all could help me.  what is an LDR?  what does it do?  what does LDR stand for?
i had seen them in a couple of schematics recently and i wanted to know what they were used for.
thanks so much.
javascript:emoticon(':wink:')
shalom + godspeed.  antonio.
www.myspace.com/magnificat
MartyB
Light-Dependant Resistor.  These can be used in combilation with LEDs or standard incandescent bulbs to provide an isolated variable resistance, such as in phase shifters.  There are alot of commercially-available components that have a pre-assembled LED and LDR in a package called an optoisolator or optocoupler.  Alot of diyers will jus use a LED/LDR pair  - usually cheaper  '8)"
Peter Snowberg
Here is what a typical unit looks like...
Take care,
-Peter
Eschew paradigm obfuscation
zener
It is a resistor which resistance varies depending from how much ( or how bright) light it receives. LDRs I have encountered are MORE LIGHT=LESS RESISTANCE.
Compressors and wah (Morley) are just two effects where you can usuallly find it.
Oh yeah!
RDV
Wasn't LDR one of the presidents?
:wink:  :wink:  :wink:  :wink:  :wink:  :wink:  :wink:  :wink:
RDV
Lonehdrider
Yeah, Larry D. Roosevelt... :D
Regards,
Lone
With all the dozen's of blues songs that start "Gonna get up in the morning" , its a fact that blues musicians are apparently the only ones that actually get up in the MORNING...
StephenGiles
Have you not heard of the Church of Latter Day Resistors!
puretube
is it possible to use a GWB in a LoFi pedal?   :cry:
Hal
HAHA
its the new LoDow pedal  :)
{ antonio }
so does that mean they are the same thing as photo resistors?
Hal
