OT: Using wallwarts as power transformers, and dropping vo..
Started by sir_modulus, June 06, 2004, 09:21:40 AM
sir_modulus
Anyone know a way to get 200VAC or around there WITHOUT a Tube power transformer. Like I mean with two wallwarts or something? If I have 300VAC, is it possible to drop it to 200VAC? I would really really thank someone who could help me out.
Thanks,
Try a google search for 'voltage dividers'...
 I'm going the other way, searching for a voltage multiplier.
Sigh.
Yes. From my post a few days ago - it's hard to beat two low voltage transformers back to back. Ideally, make the secondary voltage of both transformers be the filament voltage of the tube. Hook up the transformers as P:S=>S:P where P is the primary 120Vac winding and S is the secondary winding; using 12Vac works well with 12AX7's. Full wave rectify the output primary to about 170Vdc. You can double it to about 300Vdc if you like.
