[TUBE] anybody saw the E-H ad closeup? (can`t believe pt.2)
Started by puretube, June 22, 2004, 04:23:43 PM
moosapotamus
Would these trafos (distributed by Digi-Key) do exactly the same thing if you just wired them in reverse?
http://rocky.digikey.com/WebLib/Amveco-Talema/Web%20Data/70000%20Series%20Low%20Profile%20PC%20Mount%20Transformers.pdf
Depending on the size, in single quantities they're between ~$10 and ~$30 each.
~ Charlie
moosapotamus.net
Eric H
Quote from: moosapotamusWould these trafos (distributed by Digi-Key) do exactly the same thing if you just wired them in reverse?
~ Charlie
Yes.
-Eric
" I've had it with cheap cables..."
--DougH
puretube
any transformer can be wired in reverse...  :wink:
moosapotamus
... yeah, cool.
Then, how important is the current rating for the transformer secondary, compared to the wallwart's current output? Do they need to be the same?
thx, again!
~ Charlie
moosapotamus.net
puretube
err..., a very complicated matter, to get where the E-H trafo`s are now...
