Tube Scr3eamer Woes please help
Started by Hydesg, July 04, 2004, 11:12:42 AM
Hydesg
hi guys.
spent 12 hours striaght soldering my tube screamer
without the pcb
i soldered everything on a perfboard
now, i guess i soldered every thing correctly
but theres no output at all
no sound
checked the IC voltages, correct
but when i check the voltages on Q1 n Q2
they were wrong
for Q1n Q2
the  voltages should be
E-3.0
B-3.5
C-8.8
but what ive got is
E-8.9
B-8.9
C-8.9
i was wondering if there was anything wrong somewhere
ive checked the connections around the transistors
they dont seem to be wrong
im using a npn 2sc1815 transter
and jrc4558d ic opamp
schematics can be found here
guys please help me solve this
i am having a headache now
:shock:
Look for a miswire or wr value Resistor around the transistor and check it's pinout.
Hydesg
anyone out there knows of a way
or please provide me some voltage to check with
RG's site has the excellent bias info.
 If you're getting supply voltage at all three transistor pins, pull the transistor [if socketted] and test for continuity between the E, B, and C pin sockets. DMM set to beep mode, even with the tranny's in you should not have continuity between any of either of the Q's pins.
Hydesg
hi
ive checked the voltages at the base and emiter before entering the trans
they were 4.6~
checked the continuity
nothing wrong
Fret Wire
Did you double check that you don't have one, and/or both of Q1 & Q2 pinout's reversed?
Fret Wire
(Keyser Soze)
Ed G.
I'm thinking the transistors were both put in backwards, and are acting as a 'switch' to let the supply voltage pass through.
Joe Davisson
The pinout for those transistors are different than most (flat side up):
1. base
2. collector
3. emitter
-Joe
Hydesg
i tot it's
emiter
collector
base?
or is it
1. base
2. collector
3. emitter
im confused
it's written
c1815
w 10
on the transistor chip itself
Hydesg
hi
ive changed the orientation of the chip
now
theres no voltage at Emiter
base reads 2.93 and collector reads 8.8
is there anything wrong?
Quotewhen i check the voltages on Q1 n Q2
they were wrong
but what ive got is
E-8.9
B-8.9
C-8.9
They are. It's likely that there is no connection to power ground from the emitters. I think that if you remove the battery power and measure DC resistance from the emitter pin to ground you'll find that it's open.
Hydesg
hey
guys!
thank you very much for your help
it works!
the main problem lies with the transistor
the transistor pin out is different from the schematic
thats why it didnt work!
hey
i am so happy
:D
The magic and mystery of transistors.
Transistor-based circuits are so much easier to perf than chip-based circuits, but the odds of installing a transistor with incorrect pinout assumptions seem to always be *at least* 67%.  :wink:
If you are ever using a transistor that is anything beyond a 2N3904/3906 or a 2N5088, do yourself a favour and verify the pinouts.  We've all grown up believing that the pins are laid out E-B-C on everything, but so many devices are anything but that.
A DMM with hfe testing is indispensable for setting these matters straight.  Even if you can't read the part number, you can keep rotating the transistor, and swapping between PNP and NPN until you get a sensible hfe reading.  Once you get that the labels in the meter's transistor socket will tell you the correct pinout.  You CAN get hold of device datasheets on line, but I understand that not everyone can find everything they need as easily as they'd like and not every manufacturer observes the same pinout sometimes.  If you can't read the numbers or aren't sure what to do with the suffix, that makes it even handier to just skip the datasheets and go to the meter.
Fret Wire
Congratulations! :D   Well, how does it sound?
BTW, so true, Mark. Always better to double check pinouts before assembling. One less thing to worry about if the effect doesn't fire right up.
Fret Wire
(Keyser Soze)
