where to find a 10uf mylar cap....?
Started by casey, July 05, 2004, 11:11:56 AM
casey
does anyone know where i can find a 10uf mylar cap ?
ive tried digikey, mouser, and allied electronics.....
no luck..
Casey Campbell
I gather you want a big non-polarized cap.
Many of the audiophile mags will have ads for places that carry exotic components.  Audio Express has lots of such ads.
SoundTech
I don't think I've ever seen a mylar cap that big.  Typically at about 1uf and above, you're left with electrolytics.  A 1uF mylar is pretty big, I can't imagine a 10uF one fitting into a layout very well.
I stand corrected, here's a polyester film cap at Mouser:
http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid=370162&e_categoryid=497&e_pcodeid=59809
It's still a bit large, but it could work.
Sound Tech
  (((O)))
sir_modulus
Geez, i forget what circuit it was in, but i think you're referring to a circuit with 2 10uf mylars in the PS section. IMO, tell me the schematic, and we'll give you a better PS to follow.
casey
Quote from: sir_modulusGeez, i forget what circuit it was in, but i think you're referring to a circuit with 2 10uf mylars in the PS section. IMO, tell me the schematic, and we'll give you a better PS to follow.
i am actually building a set of condenser mics for a friend.
here is the link!
http://www.prosoundweb.com/recording/tapeop/buildmic/buildmic_16_1.shtml
these are supposed to sound nice....
even if i could get a couple of 5uf, that would be cool....i found some
close, but they are 9 bucks a piece...insane.....
what other caps would work for this?  and why does the guy say
no electrolytics?
Casey Campbell
Fret Wire
Quote from: SoundTechI stand corrected, here's a polyester film cap at Mouser:
That measures .453 thick x .827 high x 1.02 long, with .886 lead spacing.
http://www.cde.com/catalogs/DME.pdf
You could always try a 10uf @ 25v or 35v tantalum cap. Very small, and sounds better than electro's, in most places in the ckt. They are, however, polarized. What ckt, and where do you want to use it?
EDIT: I stand corrected too :oops:
From your schematic, it looks like you have to go non-polar. Doesn't look to have many components, You should be able to fit that 10uf in there
Fret Wire
(Keyser Soze)
casey
Quote from: Fret Wire
You could always try a 10uf @ 25v or 35v tantalum cap. Very small, and sounds better than electro's, in most places in the ckt. They are, however, polorized. What ckt, and where do you want to use it?
can you sub a film for a mylar?
Casey Campbell
Fret Wire
Yes, no problem. The cap SoundTech recommended will work just fine. Since there is no ckt board, definately use shrink wrap to insulate the leads of all components.
Fret Wire
(Keyser Soze)
Ed G.
Quote from: casey
Correct me if I'm wrong, but "mylar" is just a trade name for polyester. Dupont owns the name, I think.
sir_modulus
There are a few mouser parts, but all are expensive. They are all metalized polypropelene (which is the alternative the article gives).
1 (min.order = 9 of these):
CDE Metallized Polypropylene Capacitors
100V 10uF 10% AXIAL @ $16.50 ea (and you hafta order nine of these)
598-100V10
2 (get 4 of these):
2.5uF 850V 10% AX @ $4.86 ea
PLEASE READ: I don't know wether the Cap SoundTech found will work. The article says Mylar or Metallized Polypropylene. His is polyester.
Fret Wire
All non-polar "film caps" (Mylar, Polypropylene, Polyester, Polystyrene) will work.
Fret Wire
(Keyser Soze)
sir_modulus
Sorry, then SoundTech's got the best deal there.
casey
i just ordered that polyester from mouser.....good work guys...
thank you...
Casey Campbell
SoundTech
Quote from: Ed G.Correct me if I'm wrong, but "mylar" is just a trade name for polyester. Dupont owns the name, I think.
Yeah, pretty much:
http://heritage.dupont.com/touchpoints/tp_1952/overview.shtml
Sound Tech
  (((O)))
Paul Perry (Frostwave)
If it's only rock & roll, I'd put a non-polar electro in there. But, I'm a tin-eared cheapskate, so...
Nota Bene: the cheapest source for high voltage, high current, high quality film capacitors in the 10uF and up range is motor run caps from air conditioning and other motor supply stores.
I'm building an AC30 clone, using 10uF/330Vac motor starting caps for the power supply. They cost me $5.23 each at my local HVAC supplies place. That is just marginally higher than the cost of a 10/10/10/10 uF four section 400V electro.
I have this concept I call The Immortal Amp.
Tube amps are already pretty tough. If you correct the obvious wearout mechanisms, you get an amp that will be running a century later, given only a supply of replacement tubes - and that can be much fewer than most of us think.
Electrolytic cap wearout is pretty predictable, and avoidable.
John Lyons
I have built several of these mics, XLR for studio and remote use as well as unbalanced 1/8" mini plug for use with a Minidisc recorder. They work very well. Not the best mic in the world by any means but they are cheap and do the job well. The nice thing is that you can make 4 or so of them and be in buisnessfor less than $100 and save your money for other recording needs while getting set up.  They take a bit of fine soldering and patience but nothing more than pedal building really.
You can build the mics as cardiod patern mics as well, even make a single stereo mic instead of individual ones.  There are a few sites with some cool mic builds which are stereo and with different parts even. Try the ESP (elliot sound...) site...lots of good stuff there.
Good luck
John
Basic Audio Pedals
www.basicaudio.net/
zachary vex
Quote from: casey
here is the link!
unfortunately, those condenser mic modules have been discontinued by Panasonic and are no longer available from digikey.
casey
Quote from: zachary vex
Quote from: casey
here is the link!
Hey Zach!
I found a replacement!  Panasonic...  Digikey Part #: P9925-ND  $1.83
I ordered them yesterday....ill let you know how they turn out.....
These are Omni....should be good to go.
Casey Campbell
zachary vex
oh, good for you!  here's a little more information on mods you can do to that mic capsule to improve distortion.  naturally, you should follow the other design as far as using the high-quality blocking cap.
http://www.linkwitzlab.com/sys_test.htm
