TS-5 TS 808 mod
Started by RobinHolmes, July 06, 2004, 12:37:10 PM
RobinHolmes
Sorry if this question is inappropriate, I have obtained the appropriate op amp to carry this out but can only find directions for a TS-9 which is different from the TS-5 I have could any one direct me to a guide to performing this mod.
Robin
If you're talking about an opamp upgrade, simply replace the Dual Oa with you're choice of a Dual OA. I would install a socket.
 Geo has dissected the TS, and text information about each section is provided.
There should be only one dual op-amp chip on the board.  Shouldn't be too hard to find once you pop the hood.  Have faith and use the force.  :)
Fret Wire
This should make it easy. Don't worry about the .22u tantalum tone cap mod. That's not an 808 mod. You can do that later if you want, plus other things.
http://home.earthlink.net/~lens/tubescrmr/ts5mods_graphic.jpg
http://home.earthlink.net/~lens/p11-amp.htm
Fret Wire
(Keyser Soze)
TheBigMan
Change R34 to 100 ohms
Change R35 to 10 kohms
It's that simple.  I've also changed the bass/distortion response in the clipping circuit and changed one of the signal diodes for a 1n4001.  Sounds really good now, although still a bit on the noisy side.
RobinHolmes
Thankyou very much this is a very cool forum.
