ot? guitar preamp...
Started by Branimir, July 07, 2004, 01:07:05 PM
Branimir
i'm building a home made all tube amp to drive my new 2x12 vintage 30' box that i'm about to build too...
and i have to wait for the output trannie and output tubes and some stuff, so i though i could make a decent solid state guitar preamp only for clean sounds...
since i have a 100w SS rack power amp in my basement, why not drive it with a SS preamp with a decent clean then trough the already mentioned guitar box...
the tube amp will take a 3 more weeks to even get started (long story), and i can make this thingy in a few days, even have a rack chassis to put it in, lots of parts at home (power trannie, resistors, caps, op-amps), so the only thing to buy would be input/output jacks and pots...
any ideas?
for a solid state guitar preamp that delievers decent clean tone, has gain, volume, mid, treble, bass controls, no reverb and can handle Boss DS2 for good distorted tone...
yep it's a bit lame, but regarding the speaker cab i think it could sound quit okay. i don't expect anything spectacular...
i remember playing a roland jazz chorus 2x12 combo 4 years ago once... i think it was solid state, sounded okay...
under okay i presume it has a "okay" clean and when using a distortion pedal infront, the highs don't smash my ears and the tone ain't muddy...
any ideas welcome!
greets from croatia!
Umor
Built: Fuzz Face, Small Stone, Trem Lune, Fet Muff, Big Muff (green), Fuxx Face, Son of Screamer, Rat, Rebote 2.5, Opamp Big Muff, EA Tremolo, Easyvibe, Axis Face Si
T-Man
iirc, the jc-120 and distortion do not get along well...
peace
For a project that took me about an hour to wire up, The Little Gem MkII, [or was that the Ruby?] anyway it has the Jfet buffer on it and it's schematic 'n Text is at Runoff Groove, Sound Samples available.
 I was just running two of them in stereo, good high end, crunches quite well with a New Clipper into 12AX7, each a nights build, [PS for 12AX7 ..I had handy, a 30VDC printer W.Wart], really sounds great with some reverb/echo. The 12AX7 accepts other effects very well, I like having that around., really warms things up alone.
 I made a 10 minute heat sink from:
 2''x2'' 'fanned out' piece of copper sheet
 1 piece of wire for around/under the OA, one side soldered to the copper sheet, the other side through the hole..
 Super Glue
 This only seems necessary for OA #2 on the first amp [?] Results must vary...
 With your speaker the amp should sound good, I'm using Magnavox Console 8'', and a 'Thrusters' cabinet for the other amp....which needs to have it's tweeter poked out :roll:
Branimir
Quote from: T-Maniirc, the jc-120 and distortion do not get along well...
dunno, it was a long time ago, i just remember it had a really cool clean tone...
Umor
