What matters - what doesn't
Started by aron, July 14, 2004, 03:25:40 PM
Paul Perry (Frostwave)
After you build something on stripboard, use a meter to check whether any trace is connected to the next trace, and whether every cut in the track is in fact a cut, BEFORE powering up.
Because, you can see the meter easier without smoke in the way :wink:
ejbasses
A nice second (or first) build is a power supply. Your going to need one and it has tons of uses aside from powering effects.
Use spare parts to build jigs and other useful bits, I built a continuity tester so i dont have to use my meter for this purpose. Check out www.diyguitarist.com for other cool ideas
take your time
Four Strings To Rule Them All And In The Darkness Bind Them
Fp-www.Tonepad.com
Use a battery for your first power up.
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
Dirk_Hendrik
Before putting IC's (opamps and other) it their sockets put the project on power and verify the supply voltage is correct and not accidently reversed.
(SME testing is annoying and expensive ) (SME??? ....Smoke Means Error)
More stuff, less fear, less  hassle and less censoring? How 'bout it??. To discuss what YOU want to discuss instead of what others decide for you. It's possible...
But not at diystompboxes.com...... regrettably
Joe Kramer
Unless it's a very, very simple project, don't sit down today and try to build something you want for tonight's rehearsal or gig.  You'll be in a hurry and that will only add more mistakes to the number of mistakes you inevitably make when you're not in a hurry.  You lived without that Super Murder-Face Fuzz this long; you can wait another day or week until you have plenty of time to enjoy building it right.
Solder first, ask questions later.
www.droolbrothers.com
guitarmonky55
Quote from: aronWhen you drill a box, use goggles. It looks and feels stupid, but it works and protects you.
protective cups are very nice too.  i learned this the hard way when i first drilled a raco box on teh back porch table without a clamp :oops:
robotboy
Still just a n00b, but...
Make sure you have transistors and IC's in your sockets before you start desoldering  8)
If you think there's something flakey about your build, there probably is.
Some cheap multimeters come with a simple transistor tester useful for determining NPN and PNP pinouts.
There's a lot of value in enjoying the effect you just built before rushing onto the next one.
It's nice to make the enclosure before you start soldering to make sure everything will fit.
Most wires don't have to be nearly as long as it seems they would.
A continuity tester can be extremely helpful when debugging.
Sometimes taking a break is a necessary step in problem solving.
Solid core wire seems great until it breaks.
What sounds great at home rarely sounds the same at band practice.
P-90's sound great as long as you're not playing near flourescent lights or a computer monitor.
Rick
The true masochist solders dressed in a bathing suit.
wampcat1
Quote from: RickThe true masochist solders dressed in a bathing suit.
*or* a birthday suit...
:lol:
JFX09
The white dot on a schematic denotes a gap wheras a black one denotes a solder junction.
MIND THE GAP !!
Happiness is a effin' hot soldering iron
kvb
Using a toothpick to open up a filled solder pad is one of the best tips I ever used.
Heat up the solder blob and then stick the toothpick in where you want the hole to be.
ConanB
Great thread, I should really spend some time reading over some of the older posts on this forum.
Filament
The support of your family while you're in the garage/lab not spending time with them.  Remember that....MarkM can back me up on that one.
This is not my large automobile
  A great time to test for non-continuity between PS +/_ is just before applying voltage for the first time.
newfish
Build an Audio Probe ('Debugging' thread).
It's the smartest 5 minutes I ever spent with a soldering iron.
Happiness is a warm etchant bath.
axg20202
axg20202
If you're a beginner, build using stock values first THEN apply mods. If you are certain you will want to try mods, socket the relevant components then get the circuit working with stock values installed. It's a good idea to research mods before you order your parts for the build.
axg20202
Buy some lead-based solder while you still can.
Measure twice, cut once.
  Yupp...the other side is: Measure long, cut twice !
  I use this second method on 'inside fit' wood pieces, and perfboard projects.
  On perf I also, sometimes, measure long, cut once, then add that 'other little circuit' instead of cutting the second time.
studiostud
Buy a Dremel.  You will not find more uses out of a single tool in anything else you will ever buy.  Period.  And buy a corded one.  You will be glad you did once you've been working on a something with it on for a long time without the worry of a dying battery.  Plus, corded power tools are usually more powerful than cordless ones.  So the benefits far exceed the drawback of not going cordless.
Jeff
Builds Completed: Big Muff. Fuzz Face. Tube Screamer. Rat. Crash Sync. Harmonic Jerkulator. 6-band EQ. Rebote 2.5. Tremulus Lune. Small Stone. Small Clone. Microamp. LPB-2. Green Ringer. Red Ranger. Orange Squeezer. SansAmp. MXR Headphone Amp. Bass Fuzz.
