Need a few thousand Morley Photo Cells
Started by nirvanas silence, July 25, 2004, 11:45:52 PM
nirvanas silence
I need about 1000 of these guys, maybe less.
http://www.tubesandmore.com/new/scripts/silverware.exe/moreinfo@d:%5Cdfs%5Celevclients%5Ccemirror%5CELEVATOR.FXP?item=R-VPC01
Its from the Morley wahs I believe.  Light resistance is under a few hundred ohms, dark is probably close to 20M.  Its very responsive as well.  Where can I get a good deal on these?
mikeb
For that number I'd start contacting the manufacturers directly, likely those based in Asia.
Mike
Paul Perry (Frostwave)
Here's 17 manufacturers from Globalspec, to get you started :shock:
Allguy International Co., LTD. Taiwan
 Cal Sensors, Inc. Santa Rosa, CA
 Che Fong Hong Electronics, Ltd. Hong Kong
 Electro-Optical Systems, Inc. Phoenixville, PA
 Fermionics Corporation Simi Valley, CA
 InfraRed Associates, Inc. Stuart, FL
 Kolmar Technologies, Inc. Newburyport, MA
 New Chien Wei Electronics Co., Ltd. Taiwan
 New England Photoconductor Corp. Norton, MA
 Perkin Elmer Optoelectronics Fremont, CA
 Photonic Detectors Inc. Simi Valley, CA
 Sen Tech Co., Ltd. Taiwan
 Silonex Inc. Canada
 Texas Optoelectronics Inc. Garland, TX
 UDT Sensors, Inc. Hawthorne, CA
http://search.globalspec.com/Search/WebSearch
WIDE specs...
 I could work with some of those...the ones I got down to about 200k [light] to 2=5 meg dark, I'm having troubles finding a useful application for them.
mikeb
Ok, so that didn't work .... for a cut of 5% of the price of the items, I'll do the leg work for you...... ;)
But seriously - if you are in a position where you need 1000 of something, you need to learn some skills as regards parts sourcing.
Good luck
Mike
