TS9 .047 cap?
Started by WorkBench, July 26, 2004, 09:22:32 PM
WorkBench
In the ts9 which .047 cap is the one that grounds AC in the feedback loop?  I am looking to raise the value of it to increase bass response!  Thank You!
Chris
All good things in all good time
cd
The one connected to the 4.7k resistor.
RDV
In which schem or layout? I know it's the one from the feedback loop to Vr.
RDV
WorkBench
I found it, Thank You very much!  By the way, what is a vr?  Anyways, I replaced the .047 with a .1 and it is incredible.  The bottom end is their now and it is not muddy at all.  I can't believe the effect this mod has on the ts9, why is it not more common?
Chris
RDV
Quote from: WorkBenchBy the way, what is a vr?  Anyways, I replaced the .047 with a .1 and it is incredible.
DIY FAQ:
Well, V.R. is voltage reference and 1/2V+ is 1/2 of your most positive voltage (usually 9 volts). Usually they are one and the same and you can typically see V.R. connected to a resistor that connects to the input of an op amp as in the Shaka Braddah 3, The Rat and many others. Basically if you see 4.5V or V.R. or 1/2V+ ( all the same), you find all the places on the schematic that reference the label and connect them together. So all of the places that reference V.R. would connect together; one of the connections actually creates V.R. or 1/2V+. The connection that usually creates V.R. or 1/2V+ aka 4.5V (for a 9V battery) usually is a voltage divider. Typically two identical resistors, one to V+ (such as 9V), the other to ground. The place where they connect is V.R. or 1/2V+.
An example of 1/2V+ also known as V.R., V.B., VREF, 1/2V+ etc...
RDV
