Thickenning and Beefing up a Dunlop Crybaby sound??
Started by Duke of Metal, August 09, 2004, 02:38:53 AM
Fret Wire
For the vocal mod, going from 33k to 68k sounds nice. Some like it less than 68k, others like the 100k the Clyde came with. So you'll want a 100k trim pot for sure.
Fret Wire
(Keyser Soze)
Duke of Metal
Quote from: Fret WireFor the vocal mod, going from 33k to 68k sounds nice. Some like it less than 68k, others like the 100k the Clyde came with. So you'll want a 100k trim pot for sure.
ok cool..  thanks guys. I'll give that a try for sure.
Duke
Duke of Metal
hey guys,
regarding pops in the switch when doing the true bypass mod.  Is says to add a 1M resistor between the Input's resistor and the ground.
where is the ground point ?  :oops:
I found that info here:
http://fuzzcentral.tripod.com/axiswah.html
Duke of Metal
Quote from: Duke of Metalhey guys,
EDIT - If i've done the buffer removal, then can I wire it so that I have going from the input resistor's point (input jack side) or from the input jack's lug (resistor side) and go to the Ground wiring point on the switch (upper left lug)??
or is it a different way of doing this?
Duke of Metal
I used this diagram to do the TB mod:
http://homepage.ntlworld.com/s.castledine/greenfuz/effects/tb4b.png
I get a small pop when I switch the pedal on/off.  i am not 100% sure about the 1M resistor installtion process.
