icl7660's working (as good as 1044's)
Started by Athin, August 11, 2004, 05:27:53 AM
Athin
Hi,
   When experimenting with icl7660's I came up with this one. Probably has a couple of design errors and the board isn't good. It's a buffered inverter oscillator driving two 7660's in a sorta push-pull fashion. Built it, works great, has enough current 4 me. You can go down with the frequency (with the 10k and 820pF it's 55kHZ, but remember that the ripples are HALF of that freq.). Built it, works flawlessly. used parts of the neutronIII schematic (filtering, probably not required, but better safe than pissed off) and the datasheet.
http://kosi.website.pl/9to18.zip
copy paste in new window or something to get the link working
DIY XOR die.
Athin
didn't actually say what's it for: converting 9V to +9V and -9V or 9V to 18V. If you can't open the .ps files here is a file with pdf's:
http://kosi.website.pl/9to18pdf.zip
DIY XOR die.
