range master mods
Started by gdmart, August 23, 2004, 08:12:24 PM
gdmart
I heard the chrispy creme pedal and was blown away,it goes way over the top.What changes would I do to my range master to get it to sound even close to this pedal?? anyone?
Pickup, depends on the pickup what results
 Wiring also the guitar wiring
 Tube reportedly these devices sound not worse through a VOX circuit of some type I think AC30 top boost or something like that [Actually this or the transistor could have easily made the top of the list in of  chain devices, every link seeming to matter on these devices].
 Q the transistor is the engine...
 C the caps if you use high end like Silver Mica and tune the values to your liking
 R possibly some mileage could be percieved by using low tolerance resistors for the bias on the base. Find the values before ordering
 S switch
 Jacks
 case
 The only thing I know about the CC is it's rep, and that it is purported to be a one Q, Ge booster.
 I kind of gave up lookng for the transistor...well I found a couple that I like, but My Rmaster sounds not like some clips, I've seen pics of Rangemasters
 cables, I noticed a big difference in different type cables, I got a big set 'o monsters about 8 years ago and have made one repair to the set.
 speakers.
 alot of this would seemingly go without saying, but in tunning a delicate/sensative/gainy HF response, all these things matter, some more than others.
STOMPmole
Doesn't that particular "rangemaster" use a Si transistor?
