decent LED mounting ring from mouser.. (more inside)
Started by bazzwazzle, August 24, 2004, 01:29:54 PM
bazzwazzle
does anyone know of a good one to purchase. Also, would I want a panel mount or a surface mount for my box. there's so many i do not know whih one to buy! :lol:  Thanks.
bazzwazzle
thanks, how do you get it to stay in place under the box? i guess it will come with directions when i receive one?
Fret Wire
Check the data sheet, it has a nut and washer. The one downside is that it goes in from the outside. That means you don't solder it in until everything is in the box. But it's not as bad as soldering the DC jacks that do the same thing. As you can see  from the data sheet, the mounting hole has to be at least .315", but less than .394".
Fret Wire
(Keyser Soze)
bazzwazzle
ya that's why i asked i saw the nut and washer and figured it went in from the outside. How bad does it look? Possible pics? Any others that aren't like that too?
Fret Wire
It doesn't look bad at all. Looks pretty trick. I brought the mounting issue up so you'd know you can't solder it into the ckt until everything is in the pedal. The other alternative is the plastic holders like you see on MXR reissues.
http://www.web-tronics.com/semiconductor-devices-lamps---displays-mounting-clips-for-leds.html
You have to be carefull when you drill the hole for these. Too big and it won't hold the LED securely.
http://www.web-tronics.com/semiconductor-devices-lamps---displays.html
Fret Wire
(Keyser Soze)
bazzwazzle
Ok, thanks. I think I'll go along with what you recommended me.
Is this an example of it:
I think that's it.
Thanks again.
Fret Wire
That's it. BTW, Circuit Specialists even gives a choice of yellow, red, or green.
Fret Wire
(Keyser Soze)
bazzwazzle
ok nice that looks sharp then, I'll take it. Thanks man.
Hal
believe it or not, the radio shack ones are decent quality, and decent prices....so if you're not making an order anyway, it might be an ok way to go....I think its something like $1 for 2 of 'em, iirc.
