MXR Envelope Filter finished (pic)
Started by jjs, August 25, 2004, 12:14:02 PM
jimbob
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
jjs
Thanks for the increasing interest and for the kind words here and in this other thread!
Quote from: brettInnovative methods.
Umm, well. It has been done before. Actually I got the idea from this here. IMHO very cool looking. Clean and professional.
http://forum.musikding.de/yabbse/index.php?board=8;action=display;threadid=640
Quote from: brettAnd fitted into an 11x6x3 box.
I thought about that myself and decided No way!!
Thought the same thing first. But I read in the tonepad build reports that someone did it, so I decided to give it a try.
But it was not so easy.
- drilled away one of the screw holes
- bended and twisted the input and output jacks
- rounded the corners of the PCB
- used 4mm pots and cut the soldering connectors on the top right one
- couldn't include a power supply connector. I wanted to, but no room.
To fit the knobs over the nut of the pots I had to file away most of the corners. So the nuts are smaller and rounder. I dont like when one can see the nuts under the knobs.
At first I didn't want to use an LED holder, but it was almost impossible to do a nice round hole with a bit more than 5mm at the exact position. I tried it with a 5mm hole, sprayed with clear coat, pushed the led through and the clear coat cracked :?. So I drilled a bigger hole and used an LED clip. Sprayed it with white primer and clear.
Quote from: jimbobawsome! reminds me of http://www.musiciansfriend.com/srs7/g=home/search/detail/base_pid/153143/
Maybe you got me here :oops:. When I folled the link I had some kind of dejavu. I browsed through my guitar magazines and there is actually a review of this in the august issue. So you probably realized the source of inspiration I had already forgotten.
Phorhas
Electron Pusher
jimbob
I know i get a lot of ideas from the internet too,,But I like yours much better than the link..Great job!
