Funny "MOJO" stuff
Started by Joe Hart, September 11, 2004, 10:45:52 AM
puretube
ya sho nuff got da mo`jo, pete: falettinmebe da 6k-th viewa ...  8)
puretube
just found more "MOJO" here:
http://www.robertkeeley.com/product.php?id=31
reading thru the lines, it seems that caps with higher tolerances
(maybe +200/-100 % ?  :lol: ) add to the magic...
[or did Iget that wrong  :?: ]
:shock:  :?  :oops:
Ge_Whiz
I suppose that by using wide-tolerance capacitors, you spread the range of sounds achieved from individual pedals, thus giving rise to SOME pedals with 'mojo' (i.e. the ones that sound right).
Nasse
QuoteI suppose that by using wide-tolerance capacitors, you spread the range of sounds achieved from individual pedals, thus giving rise to SOME pedals with 'mojo' (i.e. the ones that sound right).
Something like that (make only few pedals sound mojo) was already suggested by me on page 7. But I DID NOT HAVE AN IDEA HOW to do that... but it is o.k. to tell the percentage, not the exact component values.
puretube
it`s really time for a summary...
kiki
Quote from: puretubejust found more "MOJO" here:
:shock:  :?  :oops:
I think they really mean "low tolerance" - it's a pretty common mistake, thinking "high tolerance" means less slop.
puretube
is "slop" mojo-ish?
if yes, it`d be something the MoJo`s need;
but if less slop means less MoJo...
puretube
one of the most underestimated mojo-factors is the production date:
after the successful run of limited Santaclaus issues,
next special editions will be the X-mas Special,
and the New Year Evenger.
Later on next year: 4th of july...
:lol:
toneman
"new" MOJU, based on "BOXES" thread---
Chemically Etched/Engraved Boxes
WooHoo!!!
Oooooo, DooooNutssss!!!!!
puretube
send us all your defective de-soldered SAD1024;
we need them to put them as placebos (non-functional) into the
MoJo Chorus and Flanger-pedals series.
To hide what`s really doing the effect (MN3207), we sand those
(they look unspectacular like any single/dual opamp, anyway).
Happy reverse-engineering  :P  :twisted: !!!
This action will even rise the cult-status of the SAD,
and NOS sellers can gain much higher margins...
Joe Hart
Well, it seems that I started quite a long thread! So, I'm taking it back!! From now on please refer to the "magic" stuff we're all talking about as Mo-Joe. It will be called the Magic Mo-Joe Pedal. And if someone does not comply, I will be forced to send bad vibes your way!
Anyway, I originally started this to get some ideas. I wanted to build a pedal using lots of "secret Mo-Joe stuff." Mainly because I have some wires that were used when my son was a newborn and in VERY bad shape (check my site for details). These wires monitored his heart and his breathing -- essentially they kept him alive. And I want to design a pedal that I love so much that I will always use it, and incorporate these wires into it. That way, my guitar signal will be traveling through the very wires that kept my son alive! How's that for Mo-Joe??
Also, I am hijacking this thread (again) to send people over to a new thread that I will start right after I'm done here. I don't know how to import a link (and I don't have the thread started yet), but if you search for "Violet Ann" you will find it.
SO CHECK OUT THE "VIOLET ANN" THREAD!!!!!
Thanks.
-Joe Hart
bigjonny
Joe Hart - here's the link to the Violet Ann thread.
radio
Hi
did any allready mention the mojo "shielding color"?
just in case the hammond box wouldn't!
"true metallic laquer" like original stuff.
(hence my name "radio")
:D
Keep on soldering!
And don t burn fingers!
puretube
Joe: you got the edit-button for the topic-title in your first post...
(so you could change it to Mo-Joe).
A very heartwarming story, and I dig the "Violet Ann" idea,
though I`m afraid not to be able to participate.
(I`ll think of another way to be helpful...).
puretube
we need aged bulbs:
http://diystompboxes.com/sboxforum/viewtopic.php?t=28298
+ everybody read Jeorge Tripps speaking about MoJo from page 270 on, here:
thanx to jimbob for spreading the news! :
http://diystompboxes.com/sboxforum/viewtopic.php?p=191584#191584
puretube
we`ll print new stickers on the pedals:
NOT cloned by BOREINGER, yet
(http://diystompboxes.com/sboxforum/viewtopic.php?p=196376#196376)
Nasse
Just got killer visual idea for Mojo BOREINGER product line logo: A yellow equal sided triangle standing on its base, bold text BOREINGER bottom and picture of a copy machine over that inside the triangle.
Fret Wire
We need to hire this ad-man: Great anti-mojo ads again!
http://www.metasonix.com/TX1.htm
Fret Wire
(Keyser Soze)
Well the Ad matches the sound clip...very trashy...
birt
this is all the vintage mojo you could ever wish, i just made a poedal out of it!!!!
before i cover it with goop i'll let you in on the secrets!!!
IT'LL MAKE ME A BILLIONAIRE!!!!!!!
the specs:
-Vintage GE trannies including an AC128 and a Mullard OC44! MATCHED!!
-Vintage caps! Orange drop!, Mustard!, Paper#Foil!, Tropical Fish!, one of those little yellow butter-like caps! oil!
-Carbon comp resistors! for a nice distortion!
-A vintage JRC 4558 chip!!!!
-Perfboard!
-A Dying Battery!
-Vintage Fabric covered wire!!!!
-An NOS Telefunken Tube!!!
-Chickenhead knob!! A large one for more tone enhancing!
-A blue indicator LED!
-The unit has NO STOMPSWITCH it's meant to be on top of your amp like the original Dallas Rangemasters!
-It's completely TRUE BYPASS because it's NOT in your signal chain!!!
-All this is covered by a VINTAGE enclosure with the original CRACKLED Hammerite-like (but more viuntage) green finish!
i'm gonna be rich!
http://www.last.fm/user/birt/
