OT : IDE to USB?
Started by Michael Allen, September 14, 2004, 11:45:12 AM
Michael Allen
I want to convert an IDE cable for a floppy drive into a usb plug in. I know I can buy cables for this, but i'd rather solder up my own. I've looked for some info on it but I can't find any. Does anyone know if it can be done?
Claus H
Shugart floopydisc interface  and USB interface are completely different you can't just wire a Floppy for USB..
You can buy external Floopy drives for USB..
Claus H
"Ya' know, these days kids seem to be getting younger and younger." â€" David Foster
yano
good luck, there's probably a load of active electronics in there (its a USB device). Its the only adapter cable i've seen that requires drivers....
Something like that would be better suited to firewire though, I'd say.
Michael Allen
Hmm, guess I'll have to purchase something then...
travissk
You can either get an external enclosure, or just go for a USB floppy drive as someone up there suggested. That might be the easier (and cheaper?) option.
Gilles C
Hi, I bought 2 of these boxes from Belkin, and paid around $59.00 CAD for one that is only USB for 3 1q/4" drives and $89.00 CAD for another one that is USB/Firewire for up to 5 1/4" drives.
http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=&Section_Id=2%2000433&pcount=&Product_Id=125643&Section.Section_Path=//Root/USB/USB2%200
And they work very well.
I can change the drives I use anytime. Very useful.
That could be the best option.
Gilles
Claus H
If you want the "DIY" solution.. But this IS AN IDE NOT A FLOPPY CONTROLLER They are not interchangeable!!
http://www.necel.com/usb/en/product/upd720130.html
The "Plug" http://www.cwol.com/usb/usb-2-ide-adapter-ud200.htm contains a floppy controller chip powered by the USB
NO HARM INTENDED !!
Claus H
Claus H
Just found this.. Floppy controller to USB but not exactly a "DIY" Project !!  :)
http://www.smsc.com/main/catalog/usb97cfdc2_01.html
Later...
Claus H
Michael Allen
Wow thanks guys! So there's no way to hardwire convert IDE to USB? Dang, guess I'll be paying.
Gilles that box is rad! I might spring for one of those just because it is a very cool idea!
