Adding a line in to a ruby amp
Started by mugan, September 15, 2004, 02:52:52 PM
mugan
I was wondering about how to do this, will it work adding it in parallel with the guitar input ?
I'd like to put a cd man in this line in and play under the sun! 8)
Give the mule what he wants
niftydog
you could do that, or you could use the same input, but with appropriate attenuation to bring the line level down to instument level. Have the attenuation circuit on a switch and just make sure it's set correctly before turning the volume up!
niftydog
Shrimp down the pants!!!
mugan
i can add a "level" pot in series with the line in signal...
