slightly OT - tone resistor
Started by ESPm2M, October 02, 2004, 02:24:45 PM
ESPm2M
What value resistor, as a set tone resistor in a guitar, would roll off frequencies above 5kHz? What values for 4kHz and 6kHz?
thanks
You mean capacitor.
 For rolling off highs, that would be signal path to ground.
 Try different values starting around 100pf/.0047uf [?]...a bigger cap value starts rolling off highs at a lower frequency, smaller will let more treble through.
Steben
with resistor to ground you need to know the inductance in front of it (the value of the "coil" in H). then it should be F(requency)= 1/(2*pi*R*"H").
So R=1/(2*pi*5000Hz*H). You need to find the "H". It depends on what kind of pick-up.
Steben
Quote from: petemooreYou mean capacitor.
Well it IS possible wth a resistor, you know, see my answer. The Pickup acts as an inductor, which is a "reverse" cap (higher resistance to highs).
ESPm2M
Quote from: Stebenwith resistor to ground you need to know the inductance in front of it (the value of the "coil" in H). then it should be F(requency)= 1/(2*pi*R*"H").
9.2 Henry
How about a cap/resistor combo then (like a normal tone pot)?
