Craig Anderton's Tremolo Project
Started by jimbob, October 02, 2004, 08:29:08 PM
jimbob
Clairex CLM6000 Popular photocoupler used in many Craig Anderton designs. These have been tested to the factory spec of under 500 ohms Ron
$6.00
Clairex CLM6000 Slightly Out-of-Spec. Tested to Ron under 1K ohm.
$5.00
Clairex CLM6000 Out-of-Spec. Ron measures 1K ohm up.
$3.50
In this project..--does it really matter which of the 3 I choose? These are from small bear.
Anyone build this ? Opinions?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
RickL
I've built this (and the stereo version too I think) and I'm pretty sure I used homemade LED/LDR combos that worked. I'd say try the cheap ones first and if they don't work use the factory spec ones (order both and save the ones you don't use for another project).
