Bridge T- Notch Tone Control
Started by strungout, October 04, 2004, 03:36:34 PM
WGTP
:twisted:  I've been messing with the Muff Fuzz again, inspired by the Mosferatu, and stuck a notch on the end of it ... now I'm wondering what would happen if you started incerting diodes into the middle of the notch filter which should result in more or less clipping to the different frequencies :shock:
Stomping Out Sparks & Flames
WGTP
Another twisted thought, but a single or diode set at one end of one of the pots for either additional distortion and/or balance adjustment since the diodes will reduce the output.  A single reduces output less and creates asymmetrical distortion.   :twisted:
