Bazz Fuss
Started by yano, October 15, 2004, 01:50:16 PM
yano
I built up the Bazz Fuss v2 on my breadboard and its output seems low, so I put a little boost section after it. However, the output still seems to be lacking bass, I need to crank up my EQ on my amp. Could there be an issue with my capacitor choices?
markusw
Try increasing the 0.1 µ cap to 0.22µ or even 1µ.
Hope it helps.
Markus
Output should be quite strong from the Bazz Fuss.
yano
that's what I thought too, pete, which is why I'm confused, does the 2n5088 suffice or should I try a higher gain 2n5089?
B Tremblay
There won't be too much (audible) difference between 2N5088 and 2N5089 when used in a Darlington arrangement within the BFv2.
How low is the output?
When using a 100k-A volume pot as shown in the schematic, at what point of rotation does unity with the bypassed signal occur?
B Tremblay
runoffgroove.com
yano
I don't have a 100k Audio pot handy (i tried it with a linear), but I leave it out, because it doesn't even come close to bypassed at full volume
B Tremblay
Some component must be connected incorrectly.  Double-check everything.
B Tremblay
runoffgroove.com
Peter Snowberg
What is the level like if you tap the output between R2 and C2?
It would also be good to verify the 10x gain on the buffer stage.
Eschew paradigm obfuscation
