220pf cap in Tripple Fuzz?
Started by vseriesamps, October 15, 2004, 04:34:31 PM
vseriesamps
Hi everybody
Just wondering what the function of this cap is and how changing the value would change the tone of the effect. I just realized I accidentally used 22pf. Pedal works fine, but I'm wondering if Tim intended it to be brighter or darker or something.
Great effect, no matter what. I'd recommend it to anybody.
K
uh oh
Quote from: vseriesampsHi everybody
 Prob ly a high end rolloff cap, signal to ground or collector to base or something.
 Larger values cut more highs, smaller values let more highs through.
K
I looked that the schemtic of the Tripple Fuzz
 I belive that capacitor is in the signal path, so the opposite would be true of it's effect compared to what I typed above, about a capacitor from signal path to ground.
 The 22pf you have in there is probably cutting more lows than a 220pf would in that position, might make it a good bit thinner sounding...course now that I look at the schematic...hmmmm...let someone else try and suggest trying a larger value and see what that does.
