MID and BASS BOOST!! check this out guys!
Started by nero1985, October 16, 2004, 08:44:11 PM
nero1985
i found this MID and BASS boost on a circuit simulator and it looks like it would work just find for a guitar,, its simple and easy to build, i drew the schematics so that i could share them with you guys,  the schematics r here:     http://albums.photo.epson.com/j/AlbumIndex?u=4241292&a=31434379&f=         the file is called "BOOSTs" and its on the bottom,, see ya!
tube man in a kilt
good deal, my life is a lot easier now. thank you.
Signature:
This is a block of text that can be added to posts you make. There is a 255 character limit
elberto
just a thought--is there much 10Hz information in a typical guitar signal?
Elektrojänis
Quote from: elbertojust a thought--is there much 10Hz information in a typical guitar signal?
Not really... But if you mod the part values you can probably make it boost a bit higher too like 100Hz. Just try different cap values.
It also might be just a typing error and it might mean 100Hz
When modding keep in mind that it (I mean the bass booster) boosts everything below the "selected" frequency (or that's what it looks like to me) and ofcource the slope between the boosted and non boosted frequencies is not a brick wall (probably more like 6dB/octave).
Phorhas
how the boost frequency and band width are calculated?
Electron Pusher
Marcos - Munky
jrc4558
Just a question:
Are you shure that pin 2 and pin 4 are tied together here?
2 usually takes either Vref (if single supply) or ground (if bipolar supply), but never before I saw it tied directly to gound pin.
nero1985
well it only said that (-) goes to ground so the op amp usually needs a ground point to work with the power supply and thats where the ground usually goes,,,,,
nero1985
this is what the simulator shows
MID BOOST (pot 0%, u gotta wire in the reverse way so that u get the boost with the pot on 100%)
MID BOOST (pot 100%, u gotta wire in the reverse way so that u get the cut with the pot on 0%)
BASS BOOST (pot 0%, u gotta wire in the reverse way so that u get the cut with the pot on 100%)
BASS BOOST (pot 100%, u gotta wire in the reverse way so that u get the cut with the pot on 0%)
