My Pedal Board
Started by phillip, October 31, 2004, 08:13:32 PM
phillip
Erm...pedal board minus the board ;)  Here's the three pedals that I've settled on as really good together:
Heavily modified Telecaster > modified Ross Compressor > Liquid Drive > Tremulus Lune > Twin Amp
Sometimes I'll put the Axis Wah in front of it all, but most of the time it's just those three.  I still need to get a board to mount them on, and a case to store them in.  I'm also planning to build a power distribution box so that I can get rid of the daisy chain setup and make a nice power cord for each pedal...I think it'll make things a bit neater when the setup is finished.
Phillip
Sic
those look great, i still need to get around to making a tremelus lune
Marcos - Munky
Looks cool and very simple. I need to put my Tremulus in a enclosure, it sounds great.
troubledtom
jrc4558
Looks swell!!!
What's a Liquid Drive by the way?
phillip
Quote from: Constantin NecrasovLooks swell!!!
http://fuzzcentral.tripod.com/liquiddrive.html   :D
Phillip
RDV
Hey Phillip, did ya ever consider using the other opamp to create a volume recovery stage, or a switchable booster? Huh? Huh?
RDV
phillip
Quote from: RDVHey Phillip, did ya ever consider using the other opamp to create a volume recovery stage, or a switchable booster? Huh? Huh?
RDV
Nope I just used a 100K linear taper volume pot so that it gets louder sooner in the rotation...it's still plenty loud if needed...easily double unity.
Phillip
RDV
I did your .068uF trick and it does add some bass don't it? Would it do the same for a TS type I wonder?
RDV
phillip
Quote from: RDVI did your .068uF trick and it does add some bass don't it? Would it do the same for a TS type I wonder?
RDV
Yep, it does add a touch more bass to the circuit.  If you want even more bass you can crank it up to 0.082uF or 0.1uF.
It works on the same principle as increasing the 0.047uF capacitor in the 4K7/0.047uF setup in the TS-type circuits...just like lowering that 4K7 resistor in there will increase the amount of available drive.
Phillip
