Completely pre-drilled copper boards?
Started by ExpAnonColin, December 19, 2004, 02:12:47 PM
ExpAnonColin
Bump to try to regain interest... how is getting them custom made going, puretube?
-Colin
puretube
currently very slowly, I`m afraid - no news before april...
ExpAnonColin
Quote from: puretubecurrently very slowly, I`m afraid - no news before april...
Why not?
-Colin
puretube
ain`t got no time - too busy...
btw.: how`s GB and the guitar?
lethargytartare
Have to say this is the best idea for quick circuit production.  The pen idea is nice, but that ink is gloppy, and not nearly as easy to draw with as a nice sharpie.  Pre-drilled, solid copper board would be perfect for so many small projects too -- like the fezter valve, millenium bypass, small distortion circuits, etc.  It would make it so easy to compress designs and get smaller boards...the neatness of etched boards and the flexibility of perf.
I'm asking every company I can find about their willingness to mull it over, so if anyone latches on, I'll rush word back here!
ltt
aaronkessman
yes, the stuff exists. there's tons of it where i work, not sure where they get it, but I'd check Digikey - they order most if not all their supplies from there. I was thinking of using it, but instead of etching, using an xacto knife to score the traces in - but that's hard/dangerous work for a circuit of any size.
Connoisseur of Distortion
ExpAnonColin
Quote from: aaronkessmanyes, the stuff exists. there's tons of it where i work, not sure where they get it, but I'd check Digikey - they order most if not all their supplies from there. I was thinking of using it, but instead of etching, using an xacto knife to score the traces in - but that's hard/dangerous work for a circuit of any size.
Ooooh... please keep us updated.  You too, lethargytartare.
I am doing quite well in GB, puretube, my guitar was recently strung up and I will start finishing in a week or so.
-Colin
Paul Perry (Frostwave)
I can't see much (if any!) advantage of predrilled copper over pad.per.hole, what am i missing?
Mind you, the more different stuff the better, so i'm all for it, but???
I'd like pad per hole, but with surface mount pads scattered about!
puretube
move your mind - your (etch-resistive) pen will follow...
ExpAnonColin
Quote from: Paul Perry (Frostwave)I can't see much (if any!) advantage of predrilled copper over pad.per.hole, what am i missing?
Because you could draw the circuit on with a pen instead of trying to make ink or PnP blue stick, and you wouldn't have to drill.
-Colin
Quote from: ExpAnonColinBecause you could draw the circuit on with a pen instead of trying to make ink or PnP blue stick, and you wouldn't have to drill.-Colin
DOH! (slaps own bald head).
Right you are Colin.I'll go back to bed now... :oops:
ExpAnonColin
I think clearly people are fairly interested in it.
Any more news?
-Colin
ExpAnonColin
As pointed out by pbrommer... what about this:
http://www.vectorelect.com/Vectorbord.htm
Sroll down to the first big picture of a board... it says one side copper clad punch board.  Sounds good to me?
-Colin
Digikey and Mouser have it, but it is NOT CHEAP!!! :cry:
Fp-www.Tonepad.com
How much would you pay for square inch?
I can do 0.1" spacing for holes or any other spacing.
Fp
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
ExpAnonColin
Quote from: Paul Perry (Frostwave)Digikey and Mouser have it, but it is NOT CHEAP!!! :cry:
The vectorbord?
QuoteDigi-Key Part Number V1126-ND Price Break
1
Unit Price
$16.67000
Manufacturer Part Number 169P44WEC1
Description PC BOARD FR4 COPP-1SIDE 4.5X17.0
Quantity Available 10
JESUS!!  You could make a lot of dinero making this!
-Colin
ExpAnonColin
Quote from: Fp-www.Tonepad.comHow much would you pay for square inch?
Fp
Well...  if pad per hole is 8 sq inches for 1.50, about, and copper clad board is about $1.20 for 8 sq inches... then let's say you add that up, that's from 30c to 40c per sq inch, about.
-Colin
Fp-www.Tonepad.com
Hmm... Maybe I'll do an experiment.
I doubt it's cost effective for me to produce though.
