Bridge rectifier
Started by michael_krell, December 30, 2004, 09:24:59 PM
michael_krell
What causes a full wave bridge rectifier to overheat. The output signal is at what it should be. and the waveform looks correct, but it is getting very hot.
Hal
too much current?  Is this bridge in a pedal or a power supply?
Peter Snowberg
If nothing is hooked to the output, it should remain dead cold. If it doesn't, then one of the diodes may be partially fried.
Is the bridge made for the current that you're pulling through it?
Eschew paradigm obfuscation
Paul Marossy
It sounds to me like you are close to or are slightly  exceeding the maximum current rating of the diodes. They really shouldn't get hot, AFAIK.
