simple delay circuit
Started by michael_krell, January 03, 2005, 06:41:28 PM
michael_krell
Does anyone know of a cheap IC that is still in circulation to use for a very simple digital delay circuit that will be good for up to 250ms?
Paul Marossy
There's a couple of analog delays that could fit the bill...
michael_krell
Wow, awesome website. This info should keep me busy for hours. However it still does not answer my question. Im building something for my senior project and it requires digital delay.
Paul Marossy
I am not aware of any simple DIY digital delays, but there might be some out there. Anyone else?
Paul Marossy
You could try this one: http://www.muzique.com/schem/dod908.zip
It's not exactly simple in my book, but...
EDIT -
Here'e another one: http://www.web-ee.com/Electronic-Projects/projects/digital_echo/index.shtml
You may be able to adapt the delay section from this page: http://sound.westhost.com/project26.htm
Fret Wire
If I understand you correctly, the Robote2 delay should fit the bill.
http://www.tonepad.com/project.asp?id=27
Fret Wire
(Keyser Soze)
Travis
The rebote II is almost certainly your best bet for a small, simple delay.  It's a very nice little circuit.
Paul Marossy
Ah, I didn't know the Rebote was a digital delay. :oops:
Cool!  8)
And, isn't one of those Scott Schwartz delays based on a PT2399?
Yes, the PT-80 ( http://www.generalguitargadgets.com/diagrams/pt80schem.pdf ) uses a PT2399 chip for somewhere around 330ms delay.  The companding helps it to behave itself nicely.
Paul Marossy
Yeah, that's the one - the PT-80. That's the one I was thinking of.
