9v wall wart is 11.8v
Started by moving_electrons, January 04, 2005, 03:03:47 AM
moving_electrons
I have a 9v wall wart that I would like to use with a Small Bear Electronics "Bear Face" ( http://www.smallbearelec.com/Projects/BearFace/BearFace.htm.
The wall wart is rated at 9v and 1 amp. The voltage with no load is over 12 volts. When plugged into the Bear Face it drops to only 11.8V. It is a new transformer so I think it is normal for one of its rating with a small load. I checked another transformer I had on hand.  I got similar results.
Will this higher voltage damage or shorten the life of the germanium transistors noticeably?
Should I:
1) go ahead and use the transformer, it will be fine?
or
2) find a lower amperage rated wall wart that will get pulled down to 9v by the Bear Face circuit?
or
3) build a regulated supply and baby those transistors?
Thanks for your advice.
Better living through controlled electron movement.
Regan
I wouldn't worry about it too much.
Regan
Paul Perry (Frostwave)
You could drop the voltage with a resistor in series with the wart, maybe tweak a 5K pot to find the right value, then put a 100mfd electro after the resistor to ground.
I agree that the Bear Face should be able to handle 12v OK, but it won't sound EXACTLY the same as with 9v (might be better though.. who can say???)
RDV
moving_electrons
Quote from: RDVYou could do this.
RDV
Sounds then like I can use the wall wart for now at the 12v without worry.
Thanks RDV for the schematic and part values.  I have most of the parts as I have used a similar circuit (mirrored) for a +/- 18v supply.  That one has protection diodes on it.  Your schematic caused me to explore a bit.  I see you don't need them for the 12v operation.
I am thinking of fitting it into a small plastic sealed project box with a metal lid (heatsink the LM317).
