Ugly Face troubles
Started by PurpleTheory, January 04, 2005, 09:56:55 PM
PurpleTheory
Hello,
I've recently been building an Ugly Face, but for some reason I can't get the frequency pot to do anything. Any ideas of what I could be doing wrong?
Thanks,
Matt
freebird1127
Id love to help you but I cant find the schematic anywhere... post it?
Evan Haklar
What's the difference between incompetence and indifference?  I don't know and I don't care!
snorky
Elephants are the new skulls.
freebird1127
check the sensitivity pot for signal off the wiper, check the opto isolater circuit as well...  does the rest of it work?
Evan Haklar
PurpleTheory
I'm not totally sure if the other pots are working correctly, although i can say that they are doing something. The sensitivity pot seems to change the bass/treble and with the threshold i can hear a slight change in volume. Does that sound about right?
Thanks,
Matt
Tim Escobedo
Do you mean it won't oscillate? If pin 4 of the 7555, connected directly to V+, and it still won't oscillate, there's most likely miswiring or bad connection somewhere.  :(
If it's just that the Freq pot doesn't work, there's most likely miswiring or bad connection somewhere.
runmikeyrun
i had the same problem with mine... it would oscillate with v+ to pin 4 but otherwise wouldn't.  I rechecked everything probably 10 times and could find no reason why it wouldn't oscillate.  I finally gave up... it now rests in an old coffee can under my workbench.
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
