Phase 90 mini-toggle
Started by The_Philth, January 05, 2005, 05:57:40 PM
sidewinder
Quote from: TheBigManJust a couple of things seeing as I just did a toggle switched R28 mod.  There isn't much space in this pedal, so a DPDT toggle may not be possible.  I used an SPDT cos I've run out of SPSTs and mounted R28 on a small piece of veroboard attatched to the casing by a standoff.  It's to the right of the pedal just above the input jack, but it's a pretty tight fit.
btw, i got a mini dpdt and it fits fine. i made the hole of my casing beside the input jack and power jack.
vanhansen
Hey Vince.  Welcome to the forum.  I guess with all the emails we had going back and forth I didn't totally grasp that it actually did work with the SPST 2 lug. :oops:  I'm glad to know you got it working good.
Erik
sidewinder
hi erik, actually i had told you that it didnt and that sbecause i couldnt hear the difference :P but when i did the dpdt i kne wit worked becaus ei could hear the difference with other resistors.
